Add a vlan with wpa-psk using CLI
eddy_isere
Community Member
I must configure a Cisco Aironet 1100 :
Here is the first configuration : no vlan with 128 key WEP. I keep this configuration in wep (no associated with a vlan) for the moment.
Now I have to create a vlan associated with wpa-psk with simple config (no server manager, no radius, no eap).
For example to declare this configuration, I think to use these CLI :.
ap(config) interface Dot11Radio0.2
ap(config-subif) encapsulation dot1Q 2
ap(config-subif) bridge-group 2
ap(config-subif) exit
ap# copy running-config startup-config
AP(config)#interface dot11Radio 0.2
AP(config-if)#encryption mode ciphers tkip
AP(config-if)#ssid xxxx
AP(config-if-ssid)#authentication key-management wpa
AP(config-if-ssid)#wpa-psk ascii xxxx
Do you think that these CLI are sufficient and
have you to modify the other peripherals networks (router...).
Now with wep and no-vlan you can connect on network.
Thank you for your help.
Eddy
0 Replies 0
