10-30-2019 05:18 PM - edited 07-05-2021 11:13 AM
I am air-AP1382I-9k mobility express 8.5.151.0 in use.
But I want to change the OS to Lightweight AP Software 15.3.3-JF10 but I can't find a way even if I search the Internet.
Is there anyone you can tell me?
I want to know configuration.
Help me. T_T
10-30-2019 05:26 PM
you need to convert the AP back to CAPWAP mode:
under section:
Converting an AP from Mobility Express to CAPWAP Type
then connect to the WLC and it will pull down the software image from the controller
10-30-2019 06:03 PM
I want mobility express 8.5.151.0 to Lightweight AP Software 15.3-JF10.
I think it is not a
10-30-2019 06:05 PM
Because that's how it works and it doesn't stick to the WLC. The WLC is 2504 OS Version 8.5.151.
