11-14-2016 12:42 AM - edited 07-05-2021 06:06 AM
Hi Everybody
I have a WLC v7.4.100.0 and a AIR-CAP2602I-E-K9 and they are working perfectly. I got a new AIR-CAP2702I-E-K9 it gets an IP address but it does not talk to the WLC.
Can somebody help please.
Thank you.
Cisco IOS Software, C2700 Software (AP3G2-RCVK9W8-M), Version 15.3(3)JC, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Fri 11-Dec-15 11:55 by prod_rel_team
Antigua Board Pre-Pilot
40MB format
Tide XL MB - 40MB of flash
Initializing flashfs...
flashfs[2]: 240 files, 8 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 40900608
flashfs[2]: Bytes used: 20210688
flashfs[2]: Bytes available: 20689920
flashfs[2]: flashfs fsck took 11 seconds.
flashfs[2]: Initialization complete.
flashfs[3]: 0 files, 1 directories
flashfs[3]: 0 orphaned files, 0 orphaned directories
flashfs[3]: Total bytes: 11999232
flashfs[3]: Bytes used: 1024
flashfs[3]: Bytes available: 11998208
flashfs[3]: flashfs fsck took 1 seconds.
flashfs[3]: Initialization complete....done Initializing flashfs.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP2702I-E-K9 (PowerPC) processor (revision A0) with 376814K/134656K bytes of memory.
Processor board ID FCW2022NMXZ
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 8.2.100.0
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: ..............................
Part Number : ............................
PCB Serial Number : .....................
Top Assembly Part Number : .................
Top Assembly Serial Number : ..........................
Top Revision Number : A0
Product/Model Number : AIR-CAP2702I-E-K9
% Please define a domain-name first.
ipv6 enable
% Invalid input detected at '^' marker.
ipv6 address autoconfig
ipv6 address dhcp
Press RETURN to get started!
*Mar 1 00:00:13.479: APAVC: Initial WLAN Buffers Given to System is 2500
*Mar 1 00:00:13.527: APAVC: WlanPAKs 42878 RadioPaks 42270
*Mar 1 00:00:13.527: Starting Ethernet promiscuous mode
*Mar 1 00:00:13.535: %LWAPP-3-CLIENTERRORLOG: Load nvram:/lwapp_ap.cfg config failed, trying backup...
*Mar 1 00:00:13.535: %LWAPP-3-CLIENTERRORLOG: Load nvram:/lwapp_ap.cfg.bak config failed...
*Mar 1 00:00:14.835: %LWAPP-4-CLIENTEVENTLOG: PnP waiting for capwap init
*Mar 1 00:00:15.511: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar 1 00:00:15.575: %SYS-5-RESTART: System restarted --
*Mar 1 00:00:15.575: %SNMP-5-COLDSTART: SNMP agent on host ap is undergoing a cold start
*Mar 1 00:00:15.611: %LINK-6-UPDOWN: Interface GigabitEthernet1, changed state to up
*Mar 1 00:00:15.619: %CDP_PD-4-POWER_OK: Full power - HIGH_POWER inline power source
*Mar 1 00:00:15.627: %LWAPP-3-CLIENTERRORLOG: Load nvram:/lwapp_ap.cfg config failed, trying backup...
*Mar 1 00:00:15.627: %LWAPP-3-CLIENTERRORLOG: Load nvram:/lwapp_ap.cfg.bak config failed...
*Mar 1 00:00:15.627: spamInitRadCfg: recovery image default mode 0
lwapp_crypto_init: MIC Present and Parsed Successfully
*Mar 1 00:00:15.795: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar 1 00:00:16.607: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar 1 00:00:17.615: %LINK-5-CHANGED: Interface GigabitEthernet1, changed state to administratively down
*Mar 1 00:00:20.415: DPAA Initialization Complete
*Mar 1 00:00:20.415: %SYS-3-HARIKARI: Process DPAA INIT top-level routine exited
*Mar 1 00:00:21.415: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar 1 00:00:23.415: %LINK-6-UPDOWN: Interface BVI1, changed state to down
*Mar 1 00:00:24.415: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to down
*Mar 1 00:00:27.611: %LINK-6-UPDOWN: Interface BVI1, changed state to up
*Mar 1 00:00:28.611: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar 1 00:00:29.707: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.20.11.66, mask 255.255.255.0, hostname APcc16.7ea5.fcd8
bridge-group 1 source-learning
%Default route without gateway, if not a point-to-point interface, may impact performance
*Mar 1 00:00:34.535: %LWAPP-3-CLIENTERRORLOG: Load nvram:/lwapp_ap.cfg config failed, trying backup...
*Mar 1 00:00:34.535: %LWAPP-3-CLIENTERRORLOG: Load nvram:/lwapp_ap.cfg.bak config failed...
*Mar 1 00:00:34.535: %CAPWAP-3-EVENTLOG: No Config Present. PNP required
*Mar 1 00:00:34.539: Cert ISSUER (39): cn=Cisco Manufacturing CA SHA2,o=Cisco
%Error opening flash:/capwap-saved-config (No such file or directory)
%Error opening flash:/capwap-saved-config-bak (No such file or directory)
Not in Bound state.
*Mar 1 00:00:53.139: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.20.11.66, mask 255.255.255.0, hostname APcc16.7ea5.fcd8
Not in Bound state.
*Mar 1 00:01:08.095: %LWAPP-4-CLIENTEVENTLOG: Invoking capwap discovery
*Mar 1 00:01:11.167: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.20.11.66, mask 255.255.255.0, hostname APcc16.7ea5.fcd8
Loading http://devicehelper.cisco.com/ca/trustpool !
Not in Bound state.
*Mar 1 00:03:45.595: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.20.11.66, mask 255.255.255.0, hostname APcc16.7ea5.fcd8
Solved! Go to Solution.
11-14-2016 01:25 AM
11-14-2016 01:25 AM
For 2700, the minimum firmware is 7.6.120.X.
11-14-2016 02:25 AM
Thanks for the help.
We'll do the upgrade and check.
01-30-2017 10:40 PM
I upgraded the WLC to 8.3.102 every thing is working fine.
01-31-2017 02:33 AM
Thanks for taking the time to rate our posts. :)
