02-07-2012 05:21 AM - edited 07-03-2021 09:31 PM
Does any body know what is the maximum of simultaneous connections that the AIR-LAP1131AG-E-K9 access point supports?
Any help is much appreciated!
02-07-2012 06:09 AM
Currently it is suggested around 25 devices per radio. It really depends on the bandwidth that is required by applications. I have seen 50+ on and ap with just web and email traffic. I have also seen up to 4 with video transfers.
I know with the 7.2 code, you can specify they max user per radio or ap.
02-07-2012 06:14 AM
Hi Scott,
Thanks for your answer!
Is there any Cisco document that specifies the maxium number of simulataneous connections?
