03-19-2021 11:39 AM - edited 07-05-2021 01:25 PM
If I configure the 3602 with an AIR-RM3000AC-E-K9 module in local mode the Admin Status of the Module (Slot 2) is Enabled and the Operational Stauts is UP.
If I then change the mode of the AP to bridge the Admin Status gets disabled and the Operational Status is set to "Down":
The RAP Downlink Backhaul is configured to use 2.4GHz. Isn't it possible to use the AP as a RootAP for a Mesh Network and also enable the AC module for direct client access?
03-20-2021 01:25 AM
- Are there any additional info's in the controller logs when this is done ?
M.
03-20-2021 04:31 AM
In Management --> Logs --> Message Logs I see the following:
*spamApTask3: Mar 19 19:17:06.748: %LWAPP-3-REPLAY_ERR: spam_lrad.c:45310 The system has received replay error on slot 0, WLAN ID 0, count 3 from AP d0:c7:89:c7:84:c0 *spamApTask4: Mar 19 19:16:45.418: %CAPWAP-3-DTLS_CLOSED_ERR: capwap_ac_sm.c:7130 0c:68:03:39:c2:80: DTLS connection closed forAP 192:168:1:71 (51013), Controller: 192:168:1:70 (5246) Normal Termination *spamApTask4: Mar 19 19:10:57.940: %LWAPP-3-VENDOR_PLD_VALIDATE_ERR: spam_lrad.c:12016 Validation of SPAM_VENDOR_SPECIFIC_PAYLOAD(185) with length=9 failed - AP 0c:68:03:39:c2:80 *spamApTask7: Mar 19 19:07:44.190: %CAPWAP-3-DTLS_CLOSED_ERR: capwap_ac_sm.c:7130 0c:68:03:39:c2:80: DTLS connection closed forAP 192:168:1:71 (51014), Controller: 192:168:1:70 (5246) Normal Termination
Are there any other logs I can look at?
03-20-2021 06:37 AM
- Could be a bug . which software version is the controller running ?
M.
03-20-2021 06:45 AM
It's currently running on version 8.5.161
03-21-2021 12:57 AM
- Have a go with 8.5.171.0 , check if that helps.
M.
03-20-2021 04:33 AM
When looking at the Trap Logs I see the following:
