Aircap 2702i E POE/Medium power
ThinkoSlo
I have many mixed APs 2600,2700,3500,3700 series on poe switch. WLC 5508 8.5.161.0 ; 15.3(3)JF12$ IOS version
All APs normal working on full poe. Only one 2700 on reduced power. No port,cable,poe fault.
One 2700 15.3(3)JF12$ IOS version; Mini IOS 8.0.115.0; Boot version 15.2.4.5> Normal full power
Second 2700 15.3(3)JF12$ IOS version; Mini IOS 8.2.100.0; Boot version 15.2.4.5 > Medium power
How to upgrade/downgrade,putty+tptf
marce1000
 - Reboot the problematic access point , just after boot connect to it and issue show logging , check powering related messages (first)
 M.
Leo Laohoo
Reboot the AP.
ThinkoSlo
Problem found.
my AP2700 and 3700 series work normal bench testing on crappy cat5 2m long on full power.
When is on 20m good  STPcat5e is reduced power.
