Aironet 1140 series units won't connect to a gigabit switch
andye8888
I just installed 2 new units and neither will connect to a new HP gigabit switch - no link light, other devices can connect to the switch OK.  Their gigabit ethernet settings are set to auto for duplex and speed.  I also tried forcing one of them to full duplex and 1000 Mbps which didn't work either.  They're both powered by POE injectors.  If I connect them to a 10/100 switch they work fine.
Am I missing something?
8 Replies 8
Leo Laohoo
If I have a dollar for situations like these, I'd be a zillionaire!
You have a cable problem.  If you can run TDR tests on the cable, you'll see that the 4th pair is not terminated.
Leo... You are a zillionaire!
-Scott
In debt, Scott.  Only in debt.  Hence I work.
I owe, I owe and off to work I go ...
HAHA... you should be a RAP artist... maybe Cisco can hire you to perform at Cisco Live in Orlando:)
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
ROFL!
I'll make a bad rap artists.
Leo,
Thanks for the reply, sorry I'm late getting back to this, I was lucky enough to have a long weekend off.
I'm no cabling expert, that's why I hired somebody else to do it.  But I have a question: should standard cat 5 cable work?
If so, I disconnect the WAP from the cabling that was installed and hooked it up with cat 5 patch cables that I confirmed to be work OK by using them to connect the gigabit switch to a laptop.  When I used the same patch cables on the WAP I still got a failure to connect to the same switch.  So unless it's not standard cat 5 that I should be using it doesn't appear that cabling is my problem.
A number of Cisco Catalyst switches support a copper line testing called TDR.
Standard Cat5 will work but you really want something better like Cat5e or Cat6 .
PS:  No cabling expert either.
Thanks for your help anyway.
