ap 1130 clients connected to wlan controller don't obtain ip from dhcp
erwee1973
I am struggling with the following issue. I have 6 1130 Accesspoints in lightweight mode connected to a 2106 wlan controller which runs software version
7.0.98.0. Everything seems to work fine. Clients can connect to the wifi network. However, they don't get an ip address from the dhcp server which is on the same subnet as the wlan controller.
See attached screenshots for configuration. I have also tried the internal dhcp server of the wlan controller, but the same problem remains.
The logs says:
Dropping primary discovery request from AP e8:b7:4x:xx:xx:xx - maximum APs joined 6/6
There are 6 AP's connected
Any help is appreciated!
With kind regards,
Ralph Willemsen
Arnhem, Netherlands
Stephen Rodriguez
What type of device is 192.168.11.1? If its running a FW, it may not like the proxy dhcp the WLC uses. You can try to disable proxy:
CLI config shop proxy disable
GUI controller > advanced> dhcp and uncheck the box for proxy
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Stephen Rodriguez
HTH,
Steve
erwee1973
Thanks a lot Stephen! This did the trick.
Cli config shop proxy disable should be: config dhcp proxy disable
Took me a while and this fixed the problem instantly :-)
Kind regards,
Ralph
glad it worked, gotta love autocorrect on the iPhone!
HTH,
Steve
Hhaha, I know the problem (on my Xperia)
Thanks!
Op vr, 12/16/2011 15.30, steprodr schreef:
Home
Re: ap 1130 clients connected to wlan controller don't obtain ip from dhcp
created by Stephen Rodriguez in Security and Network Management - View the full discussion
Reply to this message by going to Home
Start a new discussion in Security and Network Management at Home
