AP 1200 and default IP
gagirre
I'm trying to setup an 1200 AP; the problem is that I get no reponse from the default IP 10.0.0.1; I've reseted the AP, verified the switch and the ethernet wire, but i can´t connect to the AP. And I have not a console cable..
kka
Level 5
Level 5
What IOS Version are you using?
As of 12.3(2)JA the AP1200 don't use 10.0.0.1 as default IP address, but use DHCP.
kka
Level 5
Level 5
That's it. Thank you very much!
