AP 1532 Flashing Green and RED
Jose Lucas
Hello
I have a controller 5508, with, internal antennas 2700 Series and external antenas. All APs work fine, internal APs have green led and when somebody connect turn to Blue.
But with the external antenas i have the led blinking green and red, I check the AP and is perfectly recheable by ping, is registered fine on WLC,and  have user connected and ALL works fine!! ...
My question is what means blinking  Red and green ???
PD: in the WLC log not show nothing wrong
2 Accepted Solutions
jiflorwi
does your 2700 have enough power?
Mark Elsen
 - Most probably not enough power, check your ap-log (too), either from the ap-console or else from a remote connection.
M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
9 Replies 9
jiflorwi
I have the same issue. The power is normal. Only this device connected to a switch providing 150W the port can also deliver 34,4W the max usage of the AP1532E is 48V x 0,7A = 33,6W
There is no SSIDs announced,
The current power usage of the port is at around 5W
The device is UX and not enroled in any country but the Controller has only one Country code selected.
To UX device:
You will see the APs LED blinking red and green even though the AP has obtained the IP address and joined the controller. This is because there is no regulatory domain set on the AP, and it has not been primed with the correct domain.
Universal AP Regulatory Domain Deployment Guide http://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-0/AP_Regulatory_Domain_DG/b_universal_AP_regulatory_domain_DG.html
led blinking red and green and off
It's not listed....
This was a UX AP that was not attached to a region. For future referens, this is not clear in the documentation.
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/ux-ap/guide/uxap-mobapp-g.html
Mark Elsen
M.
       Beauty and terror
      Just keep going
       No feeling is final
Jose Lucas
 i was looking and inline power is close to the limit of use.
Thanks for the Hint !! I Will solve it changin some aps to other switch with more free inline power.
Jose Lucas
I have changed the AP to other switch with POE+ and enough free inline power and the problem persist.
in the AP log not show nothing rare, in the controller log the same, nothing rare.
This is the loading secuence
  • blinking green
  • Cycling through RED, GREEN, AMBER, and OFF
  • After a while blinking red and green.
In the controller i saw the AP registered OK working at fullpower 30 Watts.
Could you give any idea what could be hapenning?
Thanks!!
