AP conversion autonomous to light and networking behavior
I'm having troubles to understand the way conversion works.
I'm currently upgrading autonomous AP to light. AP are 1600, static IP configured, upgrade with the same .tar file
On a few of them, the networking configuration (static IP/DNS/NS) is kept after reboot (making capwap discovery available), and on the rest, AP is fully reset, IP returns back to DHCP (as i have no DHCP on the concerned VLAN, AP can't contact WLC)
Why do i have this behavior ? How can I keep my networking configuraton after reboot ?
Thank you!
Thibault
Rasika Nayanajith
simplest solution is get that vlan on to DHCP
Rasika
