03-26-2015 07:28 AM - edited 07-05-2021 02:48 AM
Hi i have a virtual WLC (AIR-CTVM-K9 with version 8.0.115.0) install on esxi , seems to work fine, and i manage to join the controller with AIR-2702I AP
But i don't understand when APs are in local mode i don't see at all any of my WLAN , seem that AP doesn't broadcast them
I have to go in flexconnect mode to make my wlan work
can someone point me in the right direction to look for a solution or do i have to use flexconnect mode to make it work ?
thanks
Nicolas
03-26-2015 12:58 PM
Your access-points need to be in FlexConnect mode with the vWLC. If you want to, you can access-points automatically be put into FlexConnect mode with "config ap autoconvert flexconnect" on the CLI.
03-31-2015 11:58 AM
Well I want to let you know that vWLC support LAP only in flex connect mode .
Hope this help ;)
