AP not joining WLC - Invalid country code
berembert64
Hi to everyone,
I have problems to join an AP on the controller.
AP model is: AIR-AP1242G-E-K9 (They all are the same model, already 15APs on the controller)
AP is reseted to factory default.
DEBUG OUTPUT on AP
*May 27 14:35:14.631: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*May 27 14:35:24.577: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*May 27 14:35:24.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.1.100.11 peer_port: 5246
*May 27 14:35:24.001: %CAPWAP-5-CHANGED: CAPWAP changed state to
*May 27 14:35:25.386: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.1.100.11 peer_port: 5246
*May 27 14:35:25.388: %CAPWAP-5-SENDJOIN: sending Join Request to 10.1.100.11
*May 27 14:35:25.388: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*May 27 14:35:25.498: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*May 27 14:35:25.498: %CAPWAP-3-ERRORLOG: Starting config timer
*May 27 14:35:25.503: %DTLS-5-ALERT: Received WARNING : Close notify alert from 10.1.100.11
*May 27 14:35:25.503: %DTLS-5-PEER_DISCONNECT: Peer 10.1.100.11 has closed connection.
*May 27 14:35:25.503: %DTLS-5-SEND_ALERT: Send WARNING : Close notify Alert to 10.1.100.11:5246
*May 27 14:35:25.549: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*May 27 14:35:25.552: bsnInitRcbSlot: slot 1 has NO radio
*May 27 14:35:25.559: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*May 27 14:35:25.571: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*May 27 14:35:25.574: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to down
*May 27 14:35:25.575: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
DEBUG OUTPUT on controller
(Cisco Controller) >debug capwap errors enable
*May 27 16:33:04.596: 00:24:50:10:d2:a0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 25, joined Aps =15
*May 27 16:33:04.597: 00:24:50:10:d2:a0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 25, joined Aps =15
*May 27 16:33:05.741: 00:26:99:d7:56:b0 Duplicate sequence number in request message
*May 27 16:33:16.103: 00:24:50:10:d2:a0 AP 00:24:50:10:d2:a0: Invalid country code ().
*May 27 16:33:16.104: 00:24:50:10:d2:a0 AP 00:24:50:10:d2:a0: Invalid country code ().
*May 27 16:33:16.104: 00:24:50:10:d2:a0 Regulatory Domain Mismatch: AP 00:24:50:10:d2:a0 not allowed to join. Regulatory Domain check failed.
        Allow
*May 27 16:33:16.107: 00:24:50:10:d2:a0 Failed post decode processing of config status from 10.1.100.205:57808
*May 27 16:33:16.107: 00:24:50:10:d2:a0 State machine handler: Failed to process  msg type = 5 state = 5 from 10.1.100.205:57808
*May 27 16:33:16.107: 00:24:50:10:d2:a0 Unable to release lock on AP database entry
*May 27 16:33:16.107: 00:24:50:10:d2:a0 Failed to parse CAPWAP packet from 10.1.100.205:57808
*May 27 16:33:16.109: Discarding non-ClientHello Handshake OR DTLS encrypted packet from  10.1.100.205:57808)since DTLS session is not established
If anyone could help, it would be wonderfull! If you need mote informations please let me know.
25 Replies 25
Yes, I've seen that. Maybe I need to check more than one country (actually FR only).
How can I find the Country on my AP ? I don't know the command and I can't find it on internet.
As per they query, AP model is: AIR-AP1242G-E-K9.
You have them in E-Regulatory Domain.
For more details, please refer:
http://www.cisco.com/c/en/us/products/collateral/wireless/aironet-1300-series/product_data_sheet0900aecd80537b6a.html
All my AP are in E-Regulatory Domain... And all others are working very well. This is why I'm asking help on the forum. Have a look on my precedent posts it is already explained.
Can you reboot the AP and paste the complete bootup process here from AP console.
flashfs[0]: 10 files, 3 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 15998976
flashfs[0]: Bytes used: 7424512
flashfs[0]: Bytes available: 8574464
flashfs[0]: flashfs fsck took 31 seconds.
Base ethernet MAC Address: 00:23:5e:03:1d:20
Initializing ethernet port 0...
Reset ethernet port 0...
Reset done!
ethernet link up, 100 mbps, full-duplex
Ethernet port 0 initialized: link is up
Loading "flash:/c1240-k9w8-mx.124-21a.JA/c1240-k9w8-mx.124-21a.JA"...#################################################################################################################################################################################################################################################################################################################################################################################################################################################################
File "flash:/c1240-k9w8-mx.124-21a.JA/c1240-k9w8-mx.124-21a.JA" uncompressed and installed, entry point: 0x3000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1240 Software (C1240-K9W8-M), Version 12.4(21a)JA, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 08-Jun-09 16:34 by prod_rel_team
Proceeding with system init
Proceeding to unmask interrupts
Initializing flashfs...
flashfs[1]: 10 files, 3 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 15998976
flashfs[1]: Bytes used: 7424512
flashfs[1]: Bytes available: 8574464
flashfs[1]: flashfs fsck took 6 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
Radio0  present A506 7100 E8000000 A0000000 80000000 3
Radio1 not present 0 0 0 0 0 2
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-AP1242G-E-K9     (PowerPCElvis) processor (revision A0) with 24566K/8192K bytes of memory.
Processor board ID FCW1303U0B0
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from power-on
LWAPP image version 6.0.182.0
1 FastEthernet interface
1 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:23:5E:03:1D:20
Part Number                          : 73-11479-01
PCA Assembly Number                  : 800-30493-01
PCA Revision Number                  : A0
PCB Serial Number                    : FOC125007KK
Top Assembly Part Number             : 800-29586-03
Top Assembly Serial Number           : FCW1303U0B0
Top Revision Number                  : A0
Product/Model Number                 : AIR-AP1242G-E-K9
% Please define a domain-name first.
Press RETURN to get started!
*Mar  1 00:00:07.797: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar  1 00:00:09.410: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar  1 00:00:09.540: %LWAPP-3-CLIENTEVENTLOG: Read and initialized AP event log (contains, 75 messages)
*Mar  1 00:00:11.677: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
*Mar  1 00:00:11.744: %SYS-5-RESTART: System restarted --
*Mar  1 00:00:11.744: %SNMP-5-COLDSTART: SNMP agent on host AP0023.5e03.1d20 is undergoing a cold start
*Mar  1 00:00:11.803: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
- See more at: https://supportforums.cisco.com/discussion/12518186/ap-not-joining-wlc-invalid-country-code#comment-10533876
this is not the complete logs.
Reboot and and take the logs from last 5 minute from AP console.
Sorry,
Here they are:
Y
*May 28 13:24:46.554: bsnInitRcbSlot: slot 1 has NO radio
*May 28 13:24:46.561: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*May 28 13:24:46.573: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*May 28 13:24:46.603: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*May 28 13:24:46.635: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to upXmodem file system is available.
Reset done!
executing...
           cisco Systems, Inc.
export@cisco.com.
1 802.11 Radio(s)
*Mar  1 00:00:07.798: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar  1 00:00:09.411: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar  1 00:00:09.541: %LWAPP-3-CLIENTEVENTLOG: Read and initialized AP event log (contains, 75 messages)
*Mar  1 00:00:11.678: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
*Mar  1 00:00:11.745: %SYS-5-RESTART: System restarted --
*Mar  1 00:00:11.745: %SNMP-5-COLDSTART: SNMP agent on host AP0023.5e03.1d20 is undergoing a cold start
*Mar  1 00:00:11.804: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Mar  1 00:00:11.806: bsnInitRcbSlot: slot 1 has NO radio
*Mar  1 00:00:12.033: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar  1 00:00:12.033: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:00:12.275: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 00:00:12.690: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to up
*Mar  1 00:00:13.039: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 00:00:20.157: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned DHCP address 10.1.100.205, mask 255.255.255.0, hostname AP0023.5e03.1d20
*Mar  1 00:00:30.924: Logging LWAPP message to 255.255.255.255.
*Mar  1 00:00:33.718: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
*Mar  1 00:00:33.757: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:00:34.720: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar  1 00:00:34.721: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 started - CLI initiated
Translating "CISCO-CAPWAP-CONTROLLER.volcom.com"...domain server (10.29.130.67) [OK]
Translating "CISCO-LWAPP-CONTROLLER.volcom.com"...domain server (10.29.130.67) [OK]
*Mar  1 00:00:41.671: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:00:52.683: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*May 28 13:26:57.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.1.100.11 peer_port: 5246
*May 28 13:26:58.001: %CAPWAP-5-CHANGED: CAPWAP changed state to
*May 28 13:26:59.389: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.1.100.11 peer_port: 5246
*May 28 13:26:59.390: %CAPWAP-5-SENDJOIN: sending Join Request to 10.1.100.11
*May 28 13:26:59.390: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*May 28 13:26:59.517: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*May 28 13:26:59.517: %CAPWAP-3-ERRORLOG: Starting config timer
*May 28 13:26:59.521: %DTLS-5-ALERT: Received WARNING : Close notify alert from 10.1.100.11
*May 28 13:26:59.521: %DTLS-5-PEER_DISCONNECT: Peer 10.1.100.11 has closed connection.
*May 28 13:26:59.522: %DTLS-5-SEND_ALERT: Send WARNING : Close notify Alert to 10.1.100.11:5246
*May 28 13:26:59.571: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*May 28 13:26:59.572: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*May 28 13:26:59.576: bsnInitRcbSlot: slot 1 has NO radio
*May 28 13:26:59.584: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*May 28 13:26:59.595: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*May 28 13:26:59.626: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to down
*May 28 13:26:59.657: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*May 28 13:27:09.603: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*May 28 13:27:10.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.1.100.11 peer_port: 5246
*May 28 13:27:10.001: %CAPWAP-5-CHANGED: CAPWAP changed state to
*May 28 13:27:11.398: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.1.100.11 peer_port: 5246
*May 28 13:27:11.399: %CAPWAP-5-SENDJOIN: sending Join Request to 10.1.100.11
*May 28 13:27:11.399: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*May 28 13:27:11.507: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*May 28 13:27:11.507: %CAPWAP-3-ERRORLOG: Starting config timer
*May 28 13:27:11.512: %DTLS-5-ALERT: Received WARNING : Close notify alert from 10.1.100.11
*May 28 13:27:11.512: %DTLS-5-PEER_DISCONNECT: Peer 10.1.100.11 has closed connection.
*May 28 13:27:11.512: %DTLS-5-SEND_ALERT: Send WARNING : Close notify Alert to 10.1.100.11:5246
*May 28 13:27:11.559: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*May 28 13:27:11.562: bsnInitRcbSlot: slot 1 has NO radio
*May 28 13:27:11.570: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*May 28 13:27:11.581: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*May 28 13:27:11.612: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*May 28 13:27:11.643: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*May 28 13:27:21.590: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*May 28 13:27:21.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.1.100.11 peer_port: 5246
*May 28 13:27:21.001: %CAPWAP-5-CHANGED: CAPWAP changed state to
*May 28 13:27:22.402: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.1.100.11 peer_port: 5246
*May 28 13:27:22.404: %CAPWAP-5-SENDJOIN: sending Join Request to 10.1.100.11
*May 28 13:27:22.404: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*May 28 13:27:22.517: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*May 28 13:27:22.517: %CAPWAP-3-ERRORLOG: Starting config timer
*May 28 13:27:22.521: %DTLS-5-ALERT: Received WARNING : Close notify alert from 10.1.100.11
*May 28 13:27:22.522: %DTLS-5-PEER_DISCONNECT: Peer 10.1.100.11 has closed connection.
*May 28 13:27:22.522: %DTLS-5-SEND_ALERT: Send WARNING : Close notify Alert to 10.1.100.11:5246
*May 28 13:27:22.568: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*May 28 13:27:22.570: bsnInitRcbSlot: slot 1 has NO radio
*May 28 13:27:22.578: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*May 28 13:27:22.590: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*May 28 13:27:22.621: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*May 28 13:27:22.652: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*May 28 13:27:32.598: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*May 28 13:27:33.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.1.100.11 peer_port: 5246
*May 28 13:27:33.001: %CAPWAP-5-CHANGED: CAPWAP changed state to
*May 28 13:27:34.394: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.1.100.11 peer_port: 5246
*May 28 13:27:34.395: %CAPWAP-5-SENDJOIN: sending Join Request to 10.1.100.11
*May 28 13:27:34.395: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*May 28 13:27:34.504: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*May 28 13:27:34.504: %CAPWAP-3-ERRORLOG: Starting config timer
*May 28 13:27:34.508: %DTLS-5-ALERT: Received WARNING : Close notify alert from 10.1.100.11
*May 28 13:27:34.508: %DTLS-5-PEER_DISCONNECT: Peer 10.1.100.11 has closed connection.
*May 28 13:27:34.508: %DTLS-5-SEND_ALERT: Send WARNING : Close notify Alert to 10.1.100.11:5246
*May 28 13:27:34.555: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*May 28 13:27:34.556: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*May 28 13:27:34.558: bsnInitRcbSlot: slot 1 has NO radio
*May 28 13:27:34.566: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*May 28 13:27:34.579: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*May 28 13:27:34.639: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*May 28 13:27:38.248: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
*May 28 13:27:44.586: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*May 28 13:27:45.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.1.100.11 peer_port: 5246
*May 28 13:27:45.001: %CAPWAP-5-CHANGED: CAPWAP changed state to
*May 28 13:27:46.393: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.1.100.11 peer_port: 5246
*May 28 13:27:46.395: %CAPWAP-5-SENDJOIN: sending Join Request to 10.1.100.11
*May 28 13:27:46.395: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*May 28 13:27:46.506: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*May 28 13:27:46.506: %CAPWAP-3-ERRORLOG: Starting config timer
*May 28 13:27:46.509: %DTLS-5-ALERT: Received WARNING : Close notify alert from 10.1.100.11
*May 28 13:27:46.509: %DTLS-5-PEER_DISCONNECT: Peer 10.1.100.11 has closed connection.
*May 28 13:27:46.510: %DTLS-5-SEND_ALERT: Send WARNING : Close notify Alert to 10.1.100.11:5246
*May 28 13:27:46.555: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*May 28 13:27:46.556: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*May 28 13:27:46.558: bsnInitRcbSlot: slot 1 has NO radio
Thanks.
Can you paste from WLC:
1. Show sysinfo
2. Show time
Thanks for having a look :)
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 6.0.182.0
RTOS Version..................................... 6.0.182.0
Bootloader Version............................... 7.0.220.0
Emergency Image Version.......................... N/A
Build Type....................................... DATA + WPS
System Name...................................... FRWLC
System Location.................................. France, Anglet
System Contact................................... EU Helpdesk
System ObjectID.................................. 1.3.6.1.4.1.14179.1.1.4.3
IP Address....................................... 10.1.100.10
System Up Time................................... 38 days 1 hrs 32 mins 38 secs
System Timezone Location......................... (GMT +1:00) Amsterdam, Berlin,        Rome, Vienna
Configured Country............................... FR  - France
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +34 C
--More-- or (q)uit
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Disabled
Number of WLANs.................................. 5
3rd Party Access Point Support................... Disabled
Number of Active Clients......................... 114
Burned-in MAC Address............................ 00:26:0B:05:02:60
Crypto Accelerator 1............................. Absent
Crypto Accelerator 2............................. Absent
Power Supply 1................................... Absent
Power Supply 2................................... Present, OK
Maximum number of APs supported.................. 25
(Cisco Controller) >show time
Time............................................. Thu May 28 16:00:29 2015
Timezone delta................................... 0:0
Timezone location................................ (GMT +1:00) Amsterdam, Berlin, Rome, Vienna
NTP Servers
    NTP Polling Interval.........................     86400
     Index              NTP Server
       1     172.25.193.69
Are you splitting the Management and AP manager?
If not, what is 10.1.100.11, which is what is sending a close notify, and your WLC is showing it is .10.
is there another WLC?
HTH,
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Yes, there is a split between Management and AP manager. But no other WLC.
Brice
