AP not joining WLC
samgbuyi
Level 2
Level 2
I have AIR-CAP1532E-E-K9 which fails to broadcast signal or transmit network after joining the WLC ever since i changed from 8 port to 24 port switch, please anyone with possible help or assistance?
Instead of the stable green its going amber, red and green.
I also need assistance in setting NTP for the WLC 2504.
18 Replies 18
Leo Laohoo
Is the AP getting a valid IP address?
yes, i have the IP static on it while using the 8 port switch
it can join the WLC but not sending out signal for connection
Mark Elsen
 https://www.cisco.com/c/en/us/support/docs/wireless/4400-series-wireless-lan-controllers/113334-ntp-wlc-config-00.html
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Will this work on Catalyst 2960 L2 switch?
Sandeep Choudhary
Paste the output of these commands:
sh sysinfo from WLC
login to AP console and paste the bootup-process log.
Dont forget to rate helpful posts
Record of show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.0.115.0
Bootloader Version............................... 1.0.20
Field Recovery Image Version..................... 7.6.101.1
Firmware Version................................. PIC 20.0
Build Type....................................... DATA + WPS
System Name...................................... xxxxxxxxxxxxxxxxxxxxxx
System Location.................................. xxxxxxxxxxxxxxxxxxxxxx
System Contact................................... xxxxxxxxxxxxxxxxxxxxxx
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
IP Address....................................... xxxxxxxxxxxxxxxxxxxx
IPv6 Address..................................... ::
Last Reset....................................... Power on reset
System Up Time................................... 2 days 23 hrs 43 mins 49 secs
System Timezone Location......................... (GMT +1:00) Amsterdam, Berlin, Rome, Vienna
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
--More-- or (q)uit
Configured Country............................... xxxxxxxxxxxxxxxxxxxxxxxxxxx
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +36 C
External Temperature............................. +38 C
Fan Status....................................... 4200 rpm
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 4
Number of Active Clients......................... 68
Burned-in MAC Address............................ xxxxxxxxxxxx
Maximum number of APs supported.................. 75
System Nas-Id.................................... xxxxxxxxxxxx
WLC MIC Certificate Types........................ SHA1/SHA2
which country code you configured on WLC.
Also paste the complete logs from Access point console.
Nigeria
Scott Fella
So if you put the ap’s back to the 24 port switch, everything is working?
-Scott
That LED sequence is an indication of insufficient inline power. So it sounds like the AP isn't getting enough power to enable it's radios. Is it powered from the switch or a power injector?
This is the power requirement for that AP also:
1530I/1530E
● 24 to 57 VDC
● Power over Ethernet (PoE) (802.3at or Cisco Universal PoE [UPoE])
-Scott
Here's a link to a document that explains, among other things the meaning of each LED sequence, just search for "Checking the LEDs" in this document if you want to quickly find the relevant section:
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/1530/quick/guide/ap1532qsg.html#pgfId-69013
its powered from the switch
Is the switch PoE+?
