AP problem Cisco aironet 1040
htennapel
I have a Cisco aironet 1040.
On my Accespoint i have 2 vlans: 1 for my wifi phones and 1 for my network.
Wifi Lan has the SSID LAN with WPA enterprise authentication to a radius server(ms server 2008).
Wifi Phone has SSID PHONE and vlan 50 with local radius authentication.
This Works all fine, Except when i enable AP for my wifi phones.
When AP is enabled the authentication for my lan doesn’t go to my server but local.
How do I configure my accesspoints so that the cisco phones use the local radius server with AP and my windows computers connect using the ms radius server?
Hope some one can help
Attached is my current config.
16 Replies 16
Stephen Rodriguez
aaa group server radius rad_eap
server auth-port 1645 acct-port 1646
aaa group server radius WDS-AUTH
server auth-port 1812 acct-port 1813
aaa group server radius VOICE-AUTH
aaa authentication login eap_methods group rad_eap
Both of the SSID are calling to eap_methods.  What you need to do is configure another aaa authentication line:
** aaa authentication login phone_method group VOICE-AUTH**
then call that as your network-eap:
dot11 ssid VOICE
   vlan 50
   authentication network-eap **phone_method**
   authentication key-management cckm
Change/add the lines between the **.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Steve,
Thanks for your help!
we change the config to your example, but the windows client can't connect to the network.
There is no authentication with the autentication server.
A wireless Cisco Phone connect correct to the voice ssid
Some how the windows client do not connect “ms radius server” for autentication.
Debugging Station 38e7.d8d3.3b0a Authentication failed
Can you post your current config?
Steve
HTH,
Steve
Steve,
attached the config file
ok, so the config2 matches config1 with the exception of the ssid names which shouldn't matter.  If the client could connecet before, it should still be conecting now, unless you were matching on the SSID name in the AAA server.
Can you take a look at the eventvwr of the NPS and see what the System log says when the device failed to connect?
HTH,
Steve
HTH,
Steve
Hello Steve,
I am sorry that was the wrong config file.
Hereby the correct one.
Problem is, when wlccp is configured, the client / ap never reaches the server.
try doing a:
no aaa authentication default local
and see if that allows everything to work as it should.
HTH,
Steve
HTH,
Steve
Hello Steve,
I tried what you told,
but I still get the error "Station 001c.bf69.65d5 Authentication failed" for my windows clients
What does your NPS say is the reason for the failure?
Steve
HTH,
Steve
Steve,
Nothing, the client doesn't reach the NPS server so there is no logging on the NPS server.
The config looks fine, it should be working.  Can you try:
test aaa radius group rad_eap new user test pass cisco
It doesnt' matter if we get a pass or fail, just that we see something back from the server.  Do you know if your NPS is configured to use 1645/1646 or 1812/1813?
You may also want to do a span of the AP port when you have a client trying to authenticate and see if the packet is being sent or not.
Alternately, you can debug the radius as well.
HTH,
Steve
HTH,
Steve
Hi Steve,
The authentication goes well until
wlccp ap username AUTH-WDS password 7 xxxxxxxxxxxxxxxxxxxx
wlccp authentication-server infrastructure method_WDS-AUTH
wlccp authentication-server client eap eap_methods
wlccp authentication-server client leap method_VOICE
wlccp wds priority 61 interface BVI1
is loaded,my windows clients can't connect
Do you have more than one AP? If not there is no need to do WDS.
Steve
HTH,
Steve
Steve,
We got more then 5 AP's in our network
