AP rack mount device?
astra.wadsworth
Community Member
Hi, We're utilizing an external distributed antenna system for wireless, so the APs (1130)go in the closet. Right now we're just stacking the APs on a rackmount shelf, but we'd like to have a rackmount holder to keep the APs from falling and generally becoming a mess. Anyone know of such a device? Thanks in advance
ericgarnel
Level 11
Level 11
You can easily fashion a mounting strap with parts available from most hardware stores.
For example, Home Depot sells slotted metal straps that can be mounted to a rack and then have the APs mounted to the straps.
Here is a cheesy visual:
o o o o o o o o o o o o o o o o o o o o o o
