AP1131 case
ndr_eds
Level 2
Level 2
I have a small collection of 1131 AP's that have broken case lids, as I am sure others might also since they are a marvel of plastic engineering. Anyway,  I hate to throw away perfectly good AP's but I can't re-deploy them this way so I was wondering if anyone possibly knew of a way to buy just the plastic case from Cisco? I can imagine they will want a small fortune for just the case but thought I'd ask. Thanks.
Ravi Singh
Level 11
Level 11
I don't think there is any way to purchase Plastic case from cisco.
ndr_eds
Level 2
Level 2
Ok, what I ended up doing was taking the bad AP's that would not power up or boot and took the case off them and transferred the good AP's (that worked but had broken lids) and got three that I can now use. alhough now one of them does have "the rattle" of part of the plastic lid piece that breaks off before it breaks completely.
