AP1200 dual SSID's with 128 bit encryption
wgore
I trying to setup a AP1200 radio with two different SSID's with encryption.
Each SSID must use a different 128 bit WEP encryption.
Both SSID's must have simultaneous access to the wireless radio.
I get the client & radio associated but can not pass
data. And the Clients Link Speed is listed at 1Mbps.
Any help on the would be greatly appreciated.
smalkeric
Level 6
Level 6
The following document might give you a better understanding of multiple SSIDs,
http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo1100/accsspts/i12215ja/i12215sc/s15ssid.htm
I too have tried this (multiple SSIDs with multiple wep keys). After re-reading the document pointed to in the previous reply I still do not know how to set multiple WEP keys and assign them to the SSIDs. The document doesn't mention WEP keys at all.
Anone have a sample config using more than 1 WEP key and multiple SSIDs?
michael
I have used two SSID's on 1 A/P with each having there own WPA-PSK-TKIP. I have noticed at times that DHCP assignment is slow to the client. But ths depends on the users connecting to the A/P at one given time. I also shut down the guest SSID as well.
wgore
I have spoke with two different Cisco Engineers. And the story is, this once was possible. But due to issues encounter it is no longer available as an option.
Setting up VLAN's is the only option for this scenario.
wg
