ap1200 IOS conversion
fwilliams
Community Member
I have recently upgrade from vxworks to IOS. The conversion tool upgraded to 12.2(11) JA3. I now cannot upgrade to a higher version. When I try to upgrade it never comes back. And when I look at the access point it hasn't been upgraded. I haven't been able to find an answer in any of the cisco documentation. Anybody have an idea?
scottmac
Level 11
Level 11
After the initial change to IOS, you may have to initiate the next update via the CLI using the archive command (don't forget to shut down the radios first, use the /overwrite and /force reload (it's ALWAYS best to read the Release Notes for gotchas).
The GUI routine for the update can't find enough storage and won't delete the existing image.
I believe that once you get into the higher 12.2's or 12.3's you can use the GUI for the updates again.
Good Luck
Scott
