AP1552 Broadcasting Problem
Muharrem Canli
Community Member
Hi Experts,
We have 3 different AP1552 in sama AP group. we can reach all of them via controller. None of them have alarms on ita nd they have the exactly the same configuration.However, only one of them broadcast SSID, other AP's does not broadcast SSID which defines to AP group and does not receive any Rogue AP from neighbouhoods.
What could be the problem?
BR,Muharrem
Scott Fella
The 2.4ghz radio enabled in the mesh. I would maybe remove it from the group and add it back on to see if it glitches something. The uptime and join time are okay though correct?
-Scott
