AP2802 PoE setting
yasseryy
Frequent Visitor
Frequent Visitor
I have a registered AP2802 and connected to a 3850 switch. The AP admin status is enabled but the Oper state is down. Th power level is showing 5(*) , clean air operation status is down.  Can you help in bringing up the AP? . The switch is not PoE, so I am using a power injector for AP.
Mark Elsen
   Guess you need to investigate the issue(s) below :
>[*12/18/2017 06:10:04.5367] Radio0 not started, not enough POE power
[*12/18/2017 06:10:04.5399] Radio1 not started, not enough POE power
[*12/18/2017 06:10:04.5403] Radio0 not started, not enough POE power
[*12/18/2017 06:10:04.5407] Radio1 not started, not enough POE power
[*12/18/2017 06:10:04.5454] Radio0 not started, not enough POE power
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
7 Replies 7
Mark Elsen
 - Connect to the AP over the network logon to enable mode and issue show logging ; watchout for  errors concerning the current operational mode. If there is no network access; then connect a console cable to the AP and power-cylce ; follow the boot process and watch out for error too.
M.
       Beauty and terror
      Just keep going
       No feeling is final
Hello ,
See the below from the output , this seems a power issue. How can I configured this ? I am using TL-POE150S TP-LINK Power injector .
[*12/17/2017 13:56:17.7744] waiting for POE negotiation to complete
[*12/17/2017 13:56:20.9788] SYS-COND: AP is in critical condition
[*12/17/2017 13:56:21.1661] dtls_init: Use MIC device cert
[*12/17/2017 13:56:21.1664] dtls_init: Use MIC device cert private key
[*12/17/2017 13:56:21.1665]
[*12/17/2017 13:56:21.1665] CAPWAP State: Init
[*12/17/2017 13:56:21.1669]
[*12/17/2017 13:56:21.1669] PNP is not required, Starting CAPWAP discovery
[*12/17/2017 13:56:21.1671]
[*12/17/2017 13:56:21.1671] CAPWAP State: Discovery
[*12/17/2017 13:56:21.1694] Discovery Request sent to 10.2.1.1, discovery type STATIC_CONFIG(1)
[*12/17/2017 13:56:21.1734] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*12/17/2017 13:56:21.1735]
[*12/17/2017 13:56:21.1735] CAPWAP State: Discovery
[*12/17/2017 13:56:21.1740] Discovery Response from 10.2.1.1
[*12/18/2017 06:10:02.0003] Discovery Response from 10.2.1.1
[*12/18/2017 06:10:02.0000]
[*12/18/2017 06:10:02.0000] CAPWAP State: DTLS Setup
[*12/18/2017 06:10:02.0402] dtls_load_ca_certs: LSC Root Certificate not present
[*12/18/2017 06:10:02.1399]
[*12/18/2017 06:10:02.1399] CAPWAP State: Join
[*12/18/2017 06:10:02.1412] Sending Join request to 10.2.1.1 through port 5248
[*12/18/2017 06:10:02.1433] Invalid event 10 & state 5 combination.
[*12/18/2017 06:10:02.1433] CAPWAP SM handler: Failed to process message type 10 state 5.
[*12/18/2017 06:10:02.1433] Failed to handle capwap control message from controller - status 1
[*12/18/2017 06:10:02.1433] Failed to process encrypted capwap packet 0x1896000 from 10.2.1.1
[*12/18/2017 06:10:02.1434] Failed to send capwap message 0 to the state machine. Packet already freed.
[*12/18/2017 06:10:02.1434] IPv4 wtpProcessPacketFromSocket returned 1
[*12/18/2017 06:10:02.1435] Join Response from 10.2.1.1
[*12/18/2017 06:10:02.2175] HW CAPWAP tunnel is ADDED
[*12/18/2017 06:10:02.2306]
[*12/18/2017 06:10:02.2306] CAPWAP State: Image Data
[*12/18/2017 06:10:02.2613] do NO_UPGRADE, part1 is active part
[*12/18/2017 06:10:02.2660]
[*12/18/2017 06:10:02.2660] CAPWAP State: Configure
[*12/18/2017 06:10:02.2701] NO-ENC-PROVIDER for DOT11R_WLC_MAC_IP_PAYLOAD
[*12/18/2017 06:10:02.7574] Radio0 not started, not enough POE power
[*12/18/2017 06:10:02.7739] DOT11_DRV[0]: set_channel Channel set to 1
[*12/18/2017 06:10:03.0952] TLV-DEC-ERR: cannot process TLV for TLV_TYPES(0/0)
[*12/18/2017 06:10:03.0952] TLV-DEC-ERR: No CB for TLV_TYPES(0)
[*12/18/2017 06:10:03.1041] DOT11_DRV[0]: set_channel Channel set to 1
[*12/18/2017 06:10:03.4258] TLV-DEC-ERR: cannot process TLV for TLV_TYPES(0/0)
[*12/18/2017 06:10:03.4258] TLV-DEC-ERR: No CB for TLV_TYPES(0)
[*12/18/2017 06:10:03.5233] Radio1 not started, not enough POE power
[*12/18/2017 06:10:03.5433] DOT11_DRV[1]: set_channel Channel set to 36
[*12/18/2017 06:10:03.8815] DOT11_DRV[1]: set_channel Channel set to 36
[*12/18/2017 06:10:04.5534] TLV-DEC-ERR: cannot process TLV for TLV_TYPES(0/0)
[*12/18/2017 06:10:04.5534] TLV-DEC-ERR: No CB for TLV_TYPES(0)
[*12/18/2017 06:10:04.5624] DOT11_DRV[0]: set_channel Channel set to 1
[*12/18/2017 06:10:04.8852] TLV-DEC-ERR: cannot process TLV for TLV_TYPES(0/0)
[*12/18/2017 06:10:04.8852] TLV-DEC-ERR: No CB for TLV_TYPES(0)
[*12/18/2017 06:10:04.8874] Radio1 not started, not enough POE power
[*12/18/2017 06:10:04.9081] DOT11_DRV[1]: set_channel Channel set to 36
[*12/18/2017 06:10:05.2494] DOT11_DRV[1]: set_channel Channel set to 36
Mark Elsen
       Beauty and terror
      Just keep going
       No feeling is final
yes, I know it is a PoE issue,  but how to troubleshoot it , check the injector power given, use only certain radios enough the what supplied?
 - I don't have experience with power injectors myself; but I guess the message is rather clear and you will always want to use the full capacity of an AP. You can only check if the PI can offer more power  or google on compatible PI's for your AP model (for instance).
M.
       Beauty and terror
      Just keep going
       No feeling is final
I am using TP-Link POE-150S ,Also, I am confused of which option to use for the PI , and in what base :
installed Installed
override Override
switch-mac-address Set the MAC address of the switch port that has a Power
Injector
Also, ap power pre-standard , when should it be used ?
To update you gents, replacing the PI get it to work.
