06-30-2014
08:47 AM
- last edited on
07-05-2021
01:07 AM
by
cc_security_lab
Is application visibility control working on a foreign and anchor environment? I couldn't get foreign controller show AVC information. Foreign controller has 7.4.121 and FUS 1.9.0.
Will bandwidth rate limit in QoS work on a foreign and anchor environment?
06-30-2014 05:15 PM
In Foreign/Anchor setup, you can see AVC info from Anchor controller as all L3 traffic anchored to that controller.
Here is what AVC deployment guide states about it
"In the case of Anchor and Foreign controller’s configuration, the AVC has to be configured where the application control essentially is required. In most cases in Anchor/Foreign setups the AVC should be enabled on the Anchor controller. AVC profile enforcement will happen on the WLAN on the Anchor controller. If Anchor controller is release 7.4 or higher the above mentioned setup will work"
Refer this post as well since it discuss a topic relevant to your query as well
https://supportforums.cisco.com/discussion/12043756/qos-ssid-using-anchor-controller
Rasika
**** Pls rate all useful responses ****
07-01-2014 08:29 PM
Rasika,
Am I going to have same issue for QoS setting on the foreign controller? Can I configure QoS on the foreign controller?
