APs does not appear in AP Join Statistics of WLC 5520
GU JAHONG
I`m operating Wireless Network,
My 105 APs join WLC and running without any problems
But I Can see just 80 APs in MONITOR tab of WLC and 'show ap join stats summary all' cli command
How can i see all my APs???
Best regards
Join stats are different from what you would see in show ap summary. Join stats can be cleared and will not show you all the AP’s that are joined. If you reboot the AP’s and they join the controller, then you would see the AP’s in the list again. I don’t use the join summary to see how many AP’s I have.
-Scott
Sandeep Choudhary
Do you have enough license on the WLC ?
do you know which the model name of these 80 APs ? which software version these are running ?
Yes, I have enough license.
The models of APs are 2600,2700,2800 etc.. and software version is 8.5.161
All model is running well, and just each of models can`t appear in the result of "show ap join stats summary all"
are you running HA SSO setup means two controller in high availability ?
-Scott
