Are there limitations to wireless quality???
joshrussak
If I use a wireless digital signal to stream music videos, is it possible to be streamed with HD video and 24 bit audio without losing any quality over the transmission? And can it be done with out any wait time to buffer?
scottmac
Level 10
Level 10
IF you have good signal quality, and you can do it in ~22Mbps or less
AND there are not too many hosts on that AP
AND you have fairly efficient drivers
AND if there are no 802.11b clients in-range of the AP
(AND a few other things)
Then, yeah, sure, no problem.
Good Luck
Scott
