Association errors
Alex1231
Community Member
Hi all,
I'm having some issues with client association errors on our dash for our new network:
auth_mode='wpa3-psk' 11k='1' 11v='1' reason='reserved' radio='2' vap='4' channel='85' rssi='46'
Seems to occur on an initial connection and sometimes when roaming. The issue only occurs on 6 Ghz - If we disable 6 Ghz on the client and fall back to 5 Ghz, there is no error. Disconnecting/reconnecting to the network triggers the error.
Looking at wireshark, there doesn't appear to be anything out of the norm (4 Packets Authentication, 2 Packets association, then 4 packets for handshake):
Authentication, SN=356, FN=0, Flags =.
Authentication, SN=396, FN=0, Flags=
Authentication, SN=357, FN=0, Flags=
Authentication, SN=397, FN=0, Flags =.
Association Request, SN=358, FN=0, Flags=
Association Response, SN=0, FN=0, Flags=
Key (Message 1 of 4)
Key (Message 2 of 4)
Key (Message 3 of 4)
Key (Message 4 of 4)
<DHCP stuff>
From a performance perspective, the error isn't noticeable on the client. There is also nothing of note in the WLAN report.
We're running MR 30.7.1 / CW9166I APs / WPA3-SAE / Intel AX211 (also had same issue on Netgear A8000)
Any ideas?
21 Replies 21
Not Yet. We're still working with TAC. Almost did everything possible at the AP and Network driver ends. nothing helped out.
We are the same, also in contact with TAC. Previously we tested, iPhone and Android, same issue, we think it’s may not be related to Windows OS drivers
Here we have Intel AX211 6E 23.120.0.3, the majority of users are causing issues
@b-ganesan-srvcprvdr
on the 15th last month, mr31.1.7 was released as release candidate. in the changed log, there is a mention of <code 0 : reserved> being fixed. we upgraded but we are still having the same behaviour.
drivers version that we have tested :
these are the drivers that we tested until we found that Apple iOS is exhibiting the same behaviour previously.
22.120 : totally unable to detect 6GHz band
22.130 : totally unable to detect 6GHz band
22.140 : totally unable to detect 6GHz band
22.150 : totally unable to detect 6GHz band
22.160 : totally unable to detect 6GHz band
22.170 : able to detect 6GHz band but exhibit the same behaviour
22.180 : able to detect 6GHz band but exhibit the same behaviour
22.190 : able to detect 6GHz band but exhibit the same behaviour
22.240 : able to detect 6GHz band but exhibit the same behaviour
23.50 : able to detect 6GHz band but exhibit the same behaviour
after we upgraded to mr31.1.7, we tested the 23.130.1, Intel latest. same behaviour
badreddine
Level 4
Level 4
Hello community,
Is this an ongoing issue that hasn’t been resolved in any firmware version yet?
Thank you !
Still ongoing. I haven't had an update from cisco since May.
Alex1231
Community Member
Issue is resolved for me with MR 31.1.8
