Association problems ???
ocajica
Level 2
Level 2
Hi everybody I have a little problem, I have two Ap´s, both 1200 series, one works only with 802.11b (called A) and the other works with 802.11b and g (called B), both has the same configuration and a PC desktop with 802.11b and g card, the PC is closer to AP A , but the PC try to associate to AP B wich it´s 15 meters away, So I don´t know what parameters it´s necesary to change for the PC works with with AP A.
thanks and best regards
scottmac
Level 11
Level 11
If you're using a Cisco a/b/g NIC and client software ("ADU"), then go to the "Advanced" tab. You can select which bands to enable, and choose a preferred AP.
If it's not a Cisco NIC, most client software gives you a place to enter a preferred AP.
MS Wireless Zero Config (I believe) does not offer a preferred AP selection.
Good Luck
Scott
thanks Scott fou your response, First We are working with Dell internal wireless cards, second I´m using windows XP to manage the NIC card. Do you know If it´s possible to do that you mentioned ?
thanks
