Authentication Issue 'eapol_timeout'
moha27med
Frequent Visitor
Frequent Visitor
We are not use Authentication servers to authenticate wireless users.
Just use only WPA 2 encryption mode to authenticate wireless users.
But we identified there are a lot of EAPol timeouts happened during the client authentication
this is the error message:
auth_mode='wpa2-psk' vlan_id='70' reason='eapol_timeout' reassoc='1' radio='1' vap='2' channel='48' rssi='55'
What would be the issue for this EAPol timeouts
Is this issue occurring from end user device or Access Point side ?
How Can we minimize this eapol timeout issue?
I will be happy for any help or hits to resolve this issue
10 Replies 10
Raphael_L
Meraki Community All-Star
I don't have the answers but I find it really strange that your post is almost word for word a copy of this one : https://community.meraki.com/t5/Wireless-LAN/Authentication-Issue-EAPol-Timeout-on-WPA-2-PSK-SSID/m-p/179030
But isn't EAPoL only used for 802.1X auth ?
Yes because I have some problem, and there is no solution for it
BlakeRichardson
EAP is for Radius auth as mentioned already, I suggest you open a support ticket if you haven't already.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
KevinWaller
Community Member
I am not 100% of the cause of this. But I had this problem also. And I was able to resolve it by enabling fast roaming 802.11r. Give that a shot and let me know if that works. If your able to that is.
I was having a similar issue with a Meraki camera and enabling this resolved it, don't understand why but thanks so much for the tip, don't think I'd have tried it myself!
I am having the same issue (SSID using WPA2-PSK and clients all of a sudden showing EAPOL Timeouts, which does not make any sense), but I do not understand how enabling 802.11r could solve it, since we are using PSK. I will try it though
Did you find a solution? I seem to be having the same issue.
I selected adaptive mode in 802.11r and I didn't get any more similar logs.
Did you use adaptive mode because you were having the issue with Apple devices? Has it returned for you since then?
This started happening at a few of my networks, causing issues with iPads and iPhones.
I believe I've tried toggling 802.11r (at least on/off, maybe not to adaptive), but regardless, it still happens approximately once per month. Typically all the authentication errors will be on one AP. Rebooting it resolves until it happens again 3-6 weeks later.
Which firmware are you running? Are you using WPA2-PSK, WPA3-SAE, or something else for this SSID?
