Authentication
anthony.f
Level 2
Level 2
Hi. We currently use multiple no-name WAP devices for general access to our internal LAN. No security [I know I know]. The plan is to move those outside the network. Additionally, we now wish to ADD Cisco APs INSIDE the network. The key is that we require secure access and 'roaming.' Without a 6509, what is the best way to do this as far as enterprise authentication??
Thanks!!!
rupert.wever
Level 4
Level 4
WLC4400-series (from Airespace acquisition) are a great cerntralized-architecture solution. One benefit of the architecture is the ability to do to both security and roaming well.
Thank you SO much. I have rated your post. 🙂 If you have worked with this unit I would like to know if you ran into any snags...
