Authentification
yntheys
Community Member
I would like to know if I can make authentification first with mac-adress, and second, after with EAP-FAST on ACS server (based on user rights) ?
ankbhasi
Hi Friend,
Can you update if you are using controller based architecture or autonomous AP.
If you are using controller based lwapp architecture then yes you can have mac authentication and then get authenticated by 802.1x from ACS server based on users.
Ankur
*Pls rate all helpfull post
