Autonomous bridge connecting to LWAPP AP, possible?
Koevi Vong
Can a Cisco Autonomous Bridge connect to an LWAPP AP and re-broadcast the SSID's? As in acting like a wireless repeater?
George Stefanick
No can do my friend. Repeaters are autonomous only. When you get into lwapp you want to do bridge (mesh).
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
"Im like bacon, I make your wireless better"
Adding to George....
Repeaters are not supported when connecting to a lightweight access point.
Either
you can use MESH.
Chekc it here:
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_white_paper09186a0080b1c101.shtml
or
You can configure your AAP as Work Group Bridge (WGB) & then you can associate it to a LAP.
http://mrncciew.com/2013/04/30/wgb-with-capwap/
Dont forget to rate helpful posts
manassin
The WGB can be any Cisco Autonomous Access Point that supports the Workgroup Bridge mode and runs Cisco IOS Software Release 12.4(3g)JA or later (on 32-MB access points) or Cisco IOS Software Release 12.3(8)JEB or later (on 16-MB access points). These access points include the AP1120, AP1121, AP1130, AP1231, AP1240, and AP1310. Cisco IOS software releases prior to Cisco IOS Software Releases 12.4(3g)JA and 12.3(8)JEB are not supported.
On the wireless LAN controller, you should have software version 4.1.185.0 or later. The Workgroup Bridge mode is not supported on the controller on any of the earlier versions
Link for AP configuration as WGB:
http://www.cisco.com/c/en/us/support/docs/wireless/aironet-1200-series/68472-ap-as-wgb.html
Link for Workgroup Bridges in a Cisco Unified Wireless Network Configuration Example:
http://www.cisco.com/c/en/us/support/docs/wireless/4400-series-wireless-lan-controllers/100254-wgb-config.html
Thanks and regards,
Manas Pratap Singh.
