AVC not dropping traffic
smartnet7
I've got a cisco WLC 2504 with the latest firmware. And created an AVC profile to drop Whatsapp and Facebook traffic.
I added this to the WLAN I configurerd, but the traffic doesn't get dropped with cell phones.
If I've a cell phone which has the apps (whatsapp and Facebook) installed, AVC wont drop te traffic.
It does drop the traffic if I use a browser to go to Facebook. Is this some kind of bugg?
Tom
Unfortunately you have to wait for the next release of software code (not sure when 8.0MR1 comes it will have the updated protocol pack),.
Even if it is a bug, without updating these AVC signatures, I do not think you can fix it. Here is the release not confirming this
http://www.cisco.com/c/en/us/td/docs/wireless/controller/nbar2_prot_pack/11-0-0/b-nbar2-prot-pack-1100/b-nbar2-prot-pack-1100_chapter_010101.html#wp2108825774
Network-Based Application Recognition (NBAR2) Protocol Pack 11.0.0 support is provided for Cisco Wireless LAN Controller platforms, starting with the 8.0 release.
NBAR2 Protocol Pack 11.0.0 is supported on the following Cisco Wireless LAN Controller platforms:
  •  Cisco 5508 Wireless Controller
  •  Cisco Flex 7500 Series Wireless Controllers
  •  Cisco 8510 Wireless Controller
  •  Cisco Wireless Services Module 2 (WiSM2)
Note
  •  Cisco Wireless LAN Controller software release 8.0, uses NBAR engine 16, and contains NBAR2 Protocol Pack 9.0.0 built-in. For more information on software releases and compatible protocol packs, see Working with Protocol Packs.
  •  Though the NBAR2 protocol library and the protocol signatures support IPv6 traffic classification, Cisco Wireless LAN Controller platforms currently support only IPv4 traffic classification.
  •  The Cisco 2504 Wireless Controller supports Application Visibility and Control, but supports only built-in protocol packs present in Wireless LAN Controller software releases. It does not support downloading and installing protocol packs.
**** Pls do not forget to rate our responses if it useful ****
Rasika
7 Replies 7
Rasika Nayanajith
Hi Tom,
Pls provide the below CLI command output from your WLC to see what version of AVC engine/protocol pack version you have
show sysinfo
show avc engine version
show avc protocol-pack version
Rasika
**** Pls rate all useful responses ***
Hi Manannalage,
thank you for your quick response.
Here is the output:
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.0.100.0
Bootloader Version............................... 1.0.20
Field Recovery Image Version..................... 7.6.101.1
Firmware Version................................. PIC 16.0
Build Type....................................... DATA + WPS
System Name...................................... WLC-Glogil01
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
IP Address....................................... 172.16.16.253
IPv6 Address..................................... ::
Last Reset....................................... Software reset
System Up Time................................... 22 days 23 hrs 7 mins 20 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
--More-- or (q)uit
Configured Country............................... NL  - Netherlands
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +34 C
External Temperature............................. +38 C
Fan Status....................................... 4500 rpm
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 5
Number of Active Clients......................... 28
Burned-in MAC Address............................ 50:06:04:CB:E2:C0
Maximum number of APs supported.................. 75
System Nas-Id.................................... Cisco_cb:e2:c4
(Cisco Controller) >show avc engine version
 AVC Engine Version: 16
(Cisco Controller) >show avc protocol-pack version
 AVC Protocol Pack Name: Advanced Protocol Pack
 AVC Protocol Pack Version: 9.0
Please upgrade your AVC protocol pack to version 11.0 & see if that make any difference. Here is the required instructions
http://www.cisco.com/c/en/us/td/docs/wireless/controller/nbar2_prot_pack/11-0-0/b-nbar2-prot-pack-1100/b-nbar2-prot-pack-1100_chapter_010110.html
Rasika
Rasika,
I cannot download the protocol pack, because I have a WLC 2504. Only higher WLC models have the option to download/install protocol packs seperatly.
See URL below:
http://www.cisco.com/c/en/us/td/docs/wireless/controller/nbar2_prot_pack/6-3-0/b_nbar2_prot_pack_630/b_nbar2_prot_pack_630_chapter_01.html
Should I wait for a different firmware release for the WLC 2504? It's not a known bug that AVC does not drop certain traffic.
Note
Rasika
Thank you for your help. I guess theres nothing else I can do then wait for a new firmware release.
Tom
Hi Tom,
If possible reach TAC & see, there may be some alternatives which we do not know.
Thanks for rating responses as well
Rasika
