Best authentication method for controlling access to wlan
johnfplut
What is the best method for controlling access to a wlan with a 5508 wlan controller
The requirments are
-Needs to support all types of clients (Mac, PC, smartphones, tablets)
-Clients need to be able to connect easily and without errors or installing certs or wireless profiles etc..
-Secure
This doesn't seem like alot to ask but I keep running into problems.
What are people using?
11 Replies 11
Stephen Rodriguez
Well, this is easier than you would think actually.
-Needs to support all types of clients (Mac, PC, smartphones, tablets)  --- Limits you to PEAP and EAP-TLS all devices should support these EAP types
-Clients need to be able to connect easily and without errors or installing certs or wireless profiles etc..  -- This removes TLS as you do not want to deal with certificates, and leaves you with PEAP.  Now the user will still have to create a profile but that only takes a minute or so.
-Secure  -- PEAP is secure if you are using the right type of encryption as well, I would recommend WPA2/AES.  And it since it's EAP the user just needs to have valid domain credentials.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Jatin Katyal
I agree with stephen. Peap Mschapv2 suits your requirements.
This would help you while implementing PEAP with ACS 5 in your enviornment.
http://www.cisco.com/en/US/products/ps10315/products_configuration_example09186a0080b4cdb9.shtml
Let me know if you have some other radius server and you need help on it.
Jatin Katyal
- Do rate helpful posts -
~Jatin
I have been trying to set up PEAP with MS/Chap2 with a Windows Radius server but all the clients get cert errors. I have tried many different certs and types of certs and all clients still get cert errors.
-Is it possible to get it working without cert errors for all clients? Am I just having a problem with my cert or is this a known issue?
-Do I need to buy ACS to get it working without cert errors?
Thanks for your help.
Could you please share the error you're getting while authenticating?
are you looking inside the event viewer logs?
What all certs have you installed on the radius server and client?
Jatin Katyal
~Jatin
I am using a Geotrust QuickSSL Premium cert. I have tried generating it many different ways. When I put the cert on a wesite on my Radius server and hit it with a cert checker it says the cert chain is good.
## On the Mac I get ##
Before authenticating to the server "corp-vs-ca2.#####.com" you should examine the certificate to ensure that it is appropriate for this network.
## On Windows I get ##
The credentials provided be the server could not be validated.
Under the details it says
The server corp-vs-ca2.#####.com" presented a valid certificate issued by "GeoTrust Global CA", but GeoTrust Global CA" is not configured as a valid anchor for this profile.
I think I can fix the Windows error by pushing the cert out with a group policy, but am trying to fix all the other clients.
Thanks.
Could you please provide the whole cert chain?
Also, what error are you getting on radius server > event viewer tab?
Jatin Katyal
~Jatin
I can't find an errors in any area of the event viewer.
Here is these files cat'd together.
GeoTrustGlobalCA
GeoTrustDVSSLCA
corp-vs-ca2.########-export
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----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MIIFaDCCBFCgAwIBAgIDBo5UMA0GCSqGSIb3DQEBBQUAMGExCzAJBgNVBAYTAlVT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Are you using IAS or NPS. I can tell you where to look at logs.
The cert you provided only shows root CA somehow.
With Peap, you should have server, root CA and intermediate certificate (if any) instaled on the radius server.
On the client you should only have root CA and intermediate if (any)
To best way to check this is to uncheck the validate server certificate from the client machine and select PEAP mscahp v2 as an authentication eap method.
Jatin Katyal
~Jatin
Mac should allow you to install teh certificate into the keychain.
for windows, yes you can push it via GPO, and if you're going to do that you might as well push the profile config as well.
alternately you can just uncheck the validate server certificate checkbox in WZC.
HTH,
Steve
HTH,
Steve
Does ACS solve the issues of the cert errors on the client when you connect?
It can be addressed with IAS and NPS if we have the right chain installed.
Jatin Katyal
~Jatin
