11-12-2014 06:05 AM - edited 07-05-2021 01:55 AM
Hi ,
I am currently facing issue with bonjour gateway using mdns configuration , here is my scenario i have two devcies Apple Ipad and Laptop with reflector application when i enable multicast the connection works but when i enable mdns snooping globally and connect the devices with same ssid it doesn't work , mdns is enabled from the wlan end also need urgent help as i need to fix this today
11-12-2014 08:54 PM
What is the WLC model & software version used in this case ?
Rasika
11-14-2014 10:14 AM
it is 5508 model and software version is 7.4.121.0
