BR1310 restarting problem
s.abubasheer
Level 3
Level 3
Hi Mates,
Please I need your help to fix my old br1310 restarting problem I did a software upgrade but still can't pass it!! next is show version command result:
bridge#show version
Cisco IOS Software, C1310 Software (C1310-K9W7-M), Version 12.3(7)JA2, RELEASE S
OFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Fri 18-Nov-05 12:55 by ssearch
ROM: Bootstrap program is C1310 boot loader
BOOTLDR: C1310 Boot Loader (C1310-BOOT-M) Version 12.3(2)JA3, RELEASE SOFTWARE (
fc2)
bridge uptime is 2 hours, 2 minutes
System returned to ROM by unknown reload cause - reason ptr 0xF, PC 0x6392F8, ad
dress 0x0
System image file is "flash:/c1310-k9w7-mx.123-7.JA2/c1310-k9w7-mx.123-7.JA2"
here also another reload
bridge uptime is 35 minutes
System returned to ROM by unknown reload cause - reason ptr 0xF, PC 0x6393B0, ad
dress 0x0
saher
a-vazquez
Level 11
Level 11
I think the there is a hardware problem with the Bridge. That is the reason the bridge keeps rebooting. Are you using a power injector for this bridge. If so can you use a different power injector and check if it works.
