Bridge mode not supported for lap1261N
PaoloBoaretto
I have a WLC2504 and 2 LAP1261N (converted from autonomous to lightweight) with release 7.0.116.0 and I want to create a point-to-point mesh link between the 2 APs. When trying to change the APs mode from local to bridge I receive the message "This AP does not support bridge mode" even if the release notes say that mesh is supported on AP1261N. I tried to change the mode from gui and also from CLI. Any suggestion?
Paolo
yes sir.  Have to convert it to Autonomous (aIOS) to be able to do this on the 2.4GHz
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
12 Replies 12
Stephen Rodriguez
You can't do a MESH with the 1261, as it only has a 2.4GHz radio.
MESH links are across the 5GHz radio.  You would need to have a 1262 to be able to do this.
HTH,
Steve
HTH,
Steve
Thanks for fast replay Stephen. My reseller said me that it was possible. You sure 100%?
in aIOS you can tell it to bridge on the 2.4GHz Radio, it's not ideal but it can be done.
for WLC based:
The Cisco 1130 and 1240 ( all indoor AP ) are equipped with the following two simultaneously operating radios:
2.4-GHz radio used for client access
5-GHz radio used for data backhaul
The 5-GHz radio supports the 5.15 GHz, 5.25 GHz, 5.47, and 5.8 GHz bands.
http://www.cisco.com/en/US/docs/wireless/technology/mesh/7.0/design/guide/MeshAP_70.html
HTH,
Steve
HTH,
Steve
Yup, 100% sure .. The backhaul is built on the 5 GHz side of the AP. That AP doesnt have a 5 GHz radio ..
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
Steve, I'm not understanding if I can bridge or not on the 2.4 Ghz with LAP1261N.
Should I give any special command in the WLC?
Thanks again
So I'm confused. Can I tell to bridge on the 2.4 Ghz, maybe converting from Lightweight AP to Autonomous AP?
HTH,
Steve
HTH,
Steve
Other roads? Workgroup bridge? Does it make sense?
WGB could be an option, depending on how far away this area is, and how many users are going to need access.
HTH,
Steve
HTH,
Steve
The distance is 50 meters and the users are just 2 or 3. I've no experience in cisco mesh and workgroup bridge. What do you suggest me?
Do you know the command to tell the AP to bridge on 2,4 Ghz? I've looked the manual with no success.
Well, you'll need two aIOS AP to bridge.  and for 50m, I would recommend bridge vs WGB.
interface dot11radio0
station-role root bridge
HTH,
Steve
HTH,
Steve
I wish the WLC would call it MESH and not Bridge mode for this very issue. It can be confusing for folks.
