Brodcast specific WLAN on specific AP
ittechk4u1
Level 4
Level 4
Hello experts,
Could you please tell me how can i achienve this:
WLC: 2504
AP: 1700 series
SSID: Internel & Guest and Other
Total AP: 15
5 Out of 15 AP should only broadcast "Guest" SSID  and 3 should only brocast ""Other" and rest AP must brodcast all ssid.
How can I achieve this.
Cheers
2 Accepted Solutions
Sandeep Choudhary
Hi ITtech,
You can achieve this by Creating AP groups on WLC.
Controller > WLANs > AP groups
1. Create APG1 group and assign Guest WLAN, add 5 APs
2. Create APG2 group and assign Other WLAN, add 3 APs
Rest AP will brodacst all ssids because they will be in default-group.
Dont forget to rate helpful posts
Yes, Assignment to an AP into different AP group will reload the AP automatically and client will loose the connection. Regards Don't forget to rate helpful posts
Sandeep Choudhary
Hi ITtech,
Thank you for your response! One last question: If I create new AP group and assign to these APs then, will my client loose connection or not ? Cheers
