BYOD Solution with different product than Cisco ISE
habibalby
Will it possible to make BYOD WiFi with different product than cisco ISE? such as Dell ClearPass or some sort of other product which does support Cisco WLC 5508.
Scott Fella
Sure it's possible... Dell resells Aruba's ClearPass, so really it's up to the vendor implementing ClearPass to understand what is possible or not. Both ISE and ClearPass does OnBoarding, which is used for BYOD. Both require licenses for this added feature also. There might be other ways to achieved BYOD, but it depends in what you want and what the product can do.
-Scott
kaaftab
Level 4
Level 4
yes scott is right there are many vendors offering the same features like Aruba,ruckus(clear pass and air watch), foreScout  etc each offering similar feature
