01-28-2018 04:00 PM - edited 07-05-2021 08:10 AM
Hello I'm trying to get my AP to join my vWLC and it's not working. I've tried multiple versions of the vWLC with the same behavior. Something is wrong with my AP. It joins for a brief moment then it drops. Can you assist please. I've tried resetting through the mode button but that didn't do it. I'm using 8.3.102 for the controller version
I got some messages from the AP while joining.
Solved! Go to Solution.
01-30-2018 03:33 PM
Ok which version do you recommend?
01-30-2018 03:35 PM - edited 01-30-2018 03:36 PM
If you want to stick with 8.3 then find the latest 8.3 firmware. Don't stick with the first version that was released because I can guarantee the list of bugs are as long as a take-away menu.
01-31-2018 06:57 PM
Just to make sure as it seems you tried many things. Did you have licenses and if you does did you activated it by accepting the EULA?
Also, what the AP policy looks like? Which certificate type do you have checked?
-If I helped you somehow, please, rate it as useful.-
