C9120AXI EWC management Mac-address not changing
kna5115
Hi I am trying to change the EWC management Mac Address (0000.5e00.0101) but the command mac-address H.H.H (Manually set interface MAC address) isn't working. There is not option to change VRRP as well.
Thank you for the help
Saikat Nandy
Can you try -
EWC# wireless ewc-ap vrrp vrid <1-255>
and see if that helps you.
Saikat Nandy
Can you try -
I did try it before and there wasn't any option for vrrp or vrid
Nvm Thank you I found it.
