Can a C9100 series AP running Embedded Wireless Controller firmware
benny7
Can a C9100 series AP running Embedded Wireless Controller firmware connect function as a lightweight AP under a separate controller
We might be getting a few thousand Acces points that we would needed to factory reset so we can sell them along but to do this to the Nist 800-88 standard we would need to update them to a newer version in order follow through with all the steps.
We don't have a service contract for these units so I only have access to a limited amount of software for them.
So I'm wondering if the Wireless controller software can be used for them.
Sorry if it's incoherent, there's a lot at the moment.
Mark Elsen
  >...Can a C9100 series AP running Embedded Wireless Controller firmware connect function as a lightweight AP under a separate controller
                                       - It can't , it needs to be converted to lightweight first ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
