Can't logon to domain through a wireless connection
jasperrecto
I have a Cisco Aironet 802.11/a/b/g PCI card. When I try to log on to our company domain through the wireless connection, it gives me an error saying that the domain is not available. However, if I log on using a wired network connection, I have no problems. I can log on locally on the laptop and access our network and internet through the wireless connection. I was even able to add the laptop to the domain through the wireless connection. It's only when I try to actually log on to the domain do I have a problem. Any suggestions?
Jasper
mchin345
Level 6
Level 6
If you are using ADU also, close the ADU and then access the domain. Guess both will not function at the same time.
I was able to fix my issue by installing the latest driver.
Thanks for you suggestion.
Jasper
