Can wlc do 1ssid multiple web portal ?
i want to use single ssid for all branch. but i want to use different web portal for each branch. How to setup ? or what solution we must use.
thank you for kindly support.
Sandeep Choudhary
HI Sirphan,
As per my knowledge you can use one custom webauth or internal webpage for 1 wlan.
You need multiple wlan with multiple webauth.would need to have separate wlans per site in order to define what SSID uses what webauth page.
