07-17-2024 12:53 AM
Hi Everyone. I have been experiencing an issue where Meraki Clients' captive portal stopped displaying. I have tried setting a new SSID splash but still not working on that network. Anyone here who have experienced such an setback and successfully resolved it. Thank you.
07-17-2024 01:52 AM
Hi! From the description it seems like the Splash page/Captive portal used to work but suddently stopped. Is this the correct understanding?
Are all clients affected by this?
What happens when you forget the SSID on an affected client and reattempt the connection?
You may find this document useful:
https://documentation.meraki.com/MR/MR_Splash_Page/Splash_Page_Traffic_Flow_and_Troubleshooting
07-17-2024 04:14 AM
Let me guess, this only affects a single platform - Android or Apple?
07-17-2024 05:41 AM
I suggest you open a support case.
07-17-2024 05:07 PM
Few things that you can try:
1. Forget the SSID and then try again
2. Open browser and navigate to www.example.com or
http://escapessl.com and check if the page gets redirected to the splash page.
3. Check the Splash page frequency, reduce that to a shorter duration.
