Catalyst 9800-L Wireless Controller in HA Switching Test
Electronic20
Hi Community,
There are 2 C9800-L WLCs in HA and it is configured like this:
You want to perform a failover test, that is, disconnect the Primary WLC and see that the Backup WLC works correctly.
What would be the most appropriate way to perform the switchover:
Turn off the main WLC?
or
Disconnect all the network cables from the main WLC so that it is not connected to the NETWORK without having to turn it off?
regards
Electronic20
6 Replies 6
Leo Laohoo
Two options:
1.  Turn off the active controller; or
2.  Console into the active controller and enter the command "test crash"
Hi @Leo Laohoo
Regarding option 2, what does the "test crash" command do, does it shut down the main WLC via console?
Gives a list of options what kind of "crash" the platform can perform.
The command "test crash" is hidden and can only be invoked via the console port.
Hi @Leo Laohoo
The option of disconnecting all your network cable from the main WLC, wouldn't it be a good switching option? even though it would no longer be in NETWORK?
I generally perform the failover test based on fail senarios so I have tests against all of them
1. Physically power off primary
2. Pull cables out of primary
3. If RP going via switch infra then kill that
4. Kill uplink switch
5. etc
Just remember that you need to fail back to the primary post each test
*****Help out other by using the rating system and marking answered questions as "Answered"*****
Mark Elsen
  - In the real world a controller failure will not correspond to disconnecting power cables ; turn it off to simulate a failure. Below are a number of useful commands for querying HA states
show redundancy | i ptime|Location|Current Software state|Switchovers
show chassis
show chassis detail
show chassis ha-status local
show chassis ha-status active
show chassis ha-status standby
show chassis rmi
show redundancy
show redundancy history
show redundancy switchover history
show tech wireless redundancy
show redundancy states
 If you expect HA to be up and running the verify with:
                   9800# test wireless redundancy rping
M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
