Changing AP mode from monitor to Flex
surazb
Hi Guys,
Thanks a lot for your response and answers, helped me a lot and really appreciated.
Need one more help from you guys, i have one AP that i need to move from monitor mode to Flex mode, I have Site tag created and selected Flex profile as well under Sitetag (Not Local one). When i tried to change it from Local to Flex i don't see Flex in dropdowm.
I have number of APs in that Sitetag in flex mode working fine but only one AP that i need to change sitetag.
How can i do it only for single AP so that other APs in that sitetag will not get affect
Saikat Nandy
Simply you just need to do 'Clear'. Means -
If you just do clear, AP will reload and go back to Flex mode again (from monitor mode), provided you have correct AP Tag config.
5 Replies 5
Mark Elsen
  - What controller type and software version are you using ?
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
WLC 9800L and Version is 17.9.6
  - @surazb   >...How can i do it only for single AP so that other APs in that sitetag will not get affect
                    It's not supposed to work that way :
                    You can move an AP to a particular mode (sensor mode to local mode or flex mode)
                    using the site tag with the corresponding mode.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Saikat Nandy
Thanks Guys for help. It worked with Saikat solution. Thanks Saikat
