09-09-2011 08:31 AM - edited 07-03-2021 08:44 PM
Does anyone know how to change the password on a 861-W router. When it was set up cisco did it.
09-14-2011 07:54 AM
are you looking to change the WPA key?
dot11 ssid < your ssid >
wpa ascii < your new key at least 8 characters >
HTH,
Steve
09-14-2011 02:41 PM
is this done through telnet or hyper terminal
and is there a list of commands to go on. The original set up was done by a
cisco tech.
On Wed, Sep 14, 2011 at 10:55 AM, steprodr <
09-14-2011 02:46 PM
yes, that woudl be done via a telnet/ssh or console session to the AP.
conf t
dot11 ssid < insert your ssid ?
wpa ascii < new key>
end
that should do it.
HTH,
Steve
09-15-2011 03:06 PM
Thank you very much I will give it a shot
On Wed, Sep 14, 2011 at 5:47 PM, steprodr <
09-16-2011 11:46 AM
I am trying to log on now. Do you know the default Username and Password
On Thu, Sep 15, 2011 at 6:06 PM, Anthony Pearson <
09-16-2011 12:59 PM
default should be Cisco/Cisco
09-16-2011 07:16 PM
Thanks again
On Fri, Sep 16, 2011 at 3:59 PM, steprodr <
09-19-2011 08:22 AM
I just logged in.
ap>
I entered
ap> conf t
This was what I received back
% Invalid input detected at '^' marker.
Also for some reason people think that the passkey has to be 26 characters.
Is that true?
09-19-2011 10:18 AM
you need to enter enable mode first.
ap> enable
shoudl take you to
ap#
