Cisco 2500 wireless lan controller
nithingogineni
Community Member
we recently purchased cisco 2500 seires wireless lan controller and it is not connected to our network. I am using a  cable between management port and access controller to access the box fromGUI. when i am assigning vlan identifier as 0 i can access the controller but when i am assigning it to different Vlan Identifier i cannot access the controller. can you please advise why i cant access it when it is on different vlan identifiers.
Rasika Nayanajith
When you tag a vlan on controller management, make sure that vlan is tagged on your switch as well. For example wlc management should NOT be on vlan x if your switchport configuration is like this.
switchport
switchport trunk native vlan X
switchport mode trunk
This document should help you
http://www.cisco.com/c/en/us/support/docs/wireless/2500-series-wireless-controllers/113034-2500-deploy-guide-00.html
Rasika
*** Pls rate all useful responses ***
