Cisco 340 Wireless Bridge
jtorkos
Level 2
Level 2
I would like to replace the 340 bridges with the newer Cisco 1310 bridges. The 340 bridge has a single antenna cable attached and my question is. Could I use this cable and connect it to the 1310 bridge or do I need to replace the entire cable.
Thanks in advance.
pdotchon
Level 2
Level 2
Assuming the cable is still good, that is to say undamaged my the elements, and your current signal strength is about what it should be for your particular link, I can't see any reason to replace the cable.
-phil
