Cisco 4710 ACE syslogs generating issue
I have 4710 ACE load balancer with three virtual contexts, i have configured the three contexts with the syslog configuration to send the logs to a syslog server as below:
logging enable
logging trap 5
logging buffered 7
logging host 10.x.x.x udp/514
the issue is that i can see logs in the syslog server from Admin context  only and there are no any logs buffered or sent to the syslog server from the other two context.
Note that the ACE software version is A3(2.0).
is there any bug for this software version or any thing missing fron the configuration?
Justin Kurynny
Level 4
Level 4
Mohammed,
Please repost to the correct forum. This forum is for Wireless/Mobility Security (and Management).
You will probably find better help here: https://supportforums.cisco.com/community/netpro/security/others
Justin
