Cisco 5760 netflow not working
mcaoile
Hi Experts,
I am having issues with netflow configuration in Cisco 5760. I have looked on documents regarding netflow config commands.  It seems that netflow is not working.  I have attached the configs in the 5760.  Could you please advise if I am missing anything.
On the flow exporter, 'source port-channel' is not being accepted.  Please see below message:
  MCS-5760-1-Controlle(config-flow-exporter)#source port-channel 11
Warning: cannot use a switchport interface as source.
  'source vlan #' is the one that is accepted.  I entered vlan 249 (WLC management VLAN).
I entered the below command and says no cache.
MCS-5760-1-Controller#sh flow monitor SolarWinds-Monitor cache
% Flow Monitor: 'SolarWinds-Monitor' has no cache.
I entered the below command and says 0 bytes.
MCS-5760-1-Controller#sh flow exporter NetFlow-to-SolarWinds statistics
Flow Exporter NetFlow-to-SolarWinds:
Packet send statistics (last cleared 5d20h ago):
Successfully sent: 0 (0 bytes)
Client send statistics:
Client: Flow Monitor SolarWinds-Monitor
Records added: 0
Bytes added: 0
Please advise.
Manuelito
0 Replies 0
